Problem installing Roosters
    by bocephus450x » Thu Dec 28, 2006 6:36 pm
    Four-Fifty-X wrote:It appears that the smog bolt in your picture is angled toward the back of the back. Look at mine: it looks parallel to the shroud mount bolt.
    Can you move your smog pump wire mount to the backside of the bracket and put a nut on it?
    Or move it to the backside and run the bolt from the backside?
    that is the solution my friends....'cept you don't need a nut. move the pump to the backside and the mount has a thread in it. just put the screw in from the backside. This little tip is in the Unabikers instructions by the way. of course not having a smog pump would be the better option but perhaps he's not to that point of modification yet
