-r0b- wrote:moolooman wrote:i covered this post a back a bit, a 450r system bolts straight on with no modifcations needed. i have done this and took about 5 minutes to fit.
I just received an email from an Akrapovic rep who says their 'R' exhaust WILL NOT fix the 'X' model.
Also, someone else on here just the other day said they purchased a whole system for the "R" to put on their X and it would not fit. I believe it was a Pro-Circuit system.
Four-Fifty-X wrote:I have a R exhaust on my X as well (the can anyway). 165 or 170 should be about right. I initially tried a 165, and mid- and full- throttle at mid- and low- RPMs was not good. The 170 fixed that for me.
Also, I REALLY think you ought to open up that air box now. With the freer breathing exhaust and richer jetting, I think it's a mistake not to...
Ernie Pezz wrote:-r0b- wrote:moolooman wrote:i covered this post a back a bit, a 450r system bolts straight on with no modifcations needed. i have done this and took about 5 minutes to fit.
The only R exhaust can that will fit the X is the 2005 model. The 2005 bolts right up to the 2005 X. I'm hearing that if you go with the R full system that you will lose some of the low end grunt that the X has. Ernie
