~ wrote:Did your boys crash the one with the stiff throttle??
Maybe pressed the tube against the end of the bar?
Got dirt in it?
PM Dobent4@yahoo, he is the resident ttr 125 expert around these parts.
Just don't show your boys the pics of his wife's tricked out ttr 125.
That mistake could cost you alot...![]()
What he said! Check that cheap plastic throttle tube that all bikes come with. If it gets cracked or the throttle housing is pushed against the bars it'll be tough to move. When you install the throttle housing you should push it on till it hits the bars and then pull it back out to give it some clearance.
