by JimDirt » Wed Sep 08, 2021 5:36 pm
The float itself is adjusted via the tab that the wire loop hooks on , the flat valve is not adjustable , but if it was not replaced as well , it may have a groove in it or the rubber is bad and it will allow fuel to enter the bowl and make it overflow , the thing is , if the carb sitting is not leaking , but when you turn the valve on it does , indicates either the float is adjusted to high or the valve (needle/seat) is leaking allowing fuel to continue to fill the bowl .. that is about all there is to fix that issue , either a float issue or a needle/seat issue , one of the 2 is causing your leaking .... if you shut off the fuel valve and the bike does not leak , then one or both of the above is what is causing it
Adjusting the float itself needs to be done with the carb off and tilted sideways with the pins up so the float is hanging ,
the float level is set measuring from float bowl gasket surface on main body , tip of float tab with needle valve seated, but not depressing spring in needle. Tip body and rock float back against needle to just seat it and measure , Make sure the 2 sides of the float are not twisted so one side is higher than the other ..... The float level is 21.5 mm (0.85 in)
