Crf230f front exhaust leak fix?
  • tfreake
    by tfreake » Sun Aug 15, 2021 5:46 pm
    Hi there. Bought a 2008 Crf230f a couple months ago. It came with a T4 Pro Circuit exhaust. It had a small exhaust leak at the front flange that I can feel with my hand when running. After some riding today it got worse and sounds awful. Feels worse to the hand as well. I tightened the two nuts which weren’t loose but turned about a full turn with a 6 inch wrench. It seems to have gotten worse.
    I’ve attached a couple pictures. Doesn’t look right to me. Spacing around the exhaust flange isn’t consistent, the “insulator” looks bent (flexed) and I don’t see the “insulator band” in the parts diagram at all.
    Any thoughts what the fix should be? Thanks, Tony
    Re: Crf230f front exhaust leak fix?
    by Aussiecrf230 » Mon Aug 16, 2021 9:12 pm
    I will take a wild guess and say the gasket.
    Doesn't normally have to be overtight.
    In the pictures is the flange actually bent?
    See part 2
    https://partsfinder.onlinemicrofiche.co ... %20MUFFLER
    The pipe doesn't look centralised in exhaust port so check how things are mounted as some adjustment may be required.
    by JimDirt » Mon Aug 16, 2021 10:07 pm
    What that looks like to me is a couple things , it looks like the Crush Washer (usually copper and pliable) is most likely missing
    It looks like this:
    The second issue I see is the flange looks too large for the pipe , the pipe should fill most of that gap , so to me the pipe and flange are not meant to go together .... ... that is what I seeing those pictures ... so yea , something is not quite right ... :-k 8-[
