Jim, thanks for that info.Just go Step By Step ..... don't skim over anything , just follow the manual and it should be fine .... Once you do it , it will be a breeze the next time ............. Also when you do the seals , do both forks , that way you know there are no issues and then they both should be good to go .....
I would also recommend either OEM or SKF seals ... The SKF are a bit pricey , but are much better than All Balls or Pivot Works , etc. , which I find have a tendency to go bad fast , or just leak right off the bat , especially All Balls for some reason they have poor tolerances , and just seem to leak more than not , and just don't seem to last as long as other brands ...
Hi Back2-2, I just figured this would be considered normal wear/use and not necessarily a defect. Please let me know if I'm thinking wrong. But I assume that maybe it would also depend on how willing the dealer is to cover it as warranty?If the bike is a new 2021 as you stated - why not let the warranty cover the repair or problem.
