I just checked the parts fiche and it is the same rod/part # from 04-10 , I did not check farther than that as it would be irrelevantIs it possible that engine is on the line for what year it was manufactured and the 2004 or the 2006 clutch lifter rod is longer?
Are you sure the inner basket is seated all the way ??? .... nothing should move in/outI have notice that the Main Shaft and Bearing under the clutch basket moves out each time we torque the Pressure plate bolts. Is there anyway to fix this without splitting the cases?
