Welcome to the site !!
I guess it depends on what the bad engine needs ,and what parts you acquired and how complete they fix what is broken on the other , and what your budget is , and what condition the used parts are in
What do you know about the bad engine ??? , is the crank bad ?? ( did the valve hit the piston ?? , if so most likely the crank is toast , and also if the rod went thru the case , chances are ,everything is junk ,.... crank , piston, cylinder , head .... who knows) usually , a broken case from a rod letting loose destroys pretty much everything except the clutch and tranny .... if you have everything to complete the engine and make it run in what parts you acquired then you are maybe fine for now ,but no telling what condition the used parts are in , so again ,this door is wide open , so no telling if this will solve your issue and allow you to put it together and ride or not .... , if your budget is too tight to buy new parts , you might be in over your head in this purchase .... and may just be putting a band aid on a open wound that will continue to bleed until you fix it right with new parts ,the cases can be used , but internal parts , are usually worn to some degree or another , so you could pay for a used piston ,and end up with a worn out paperweight ,and still have to buy a new one ,so you just wasted that money ...
What I would do is buy what you can new ,and if you can't do the expensive parts , then and only then get them used if they are non critical parts like the cases or something of that nature , but be prepared to put some work or money into them to get them up to par ..... there is no way of saying , do this , or spend this and all will be well .... it just does not work that way , the result would be the same with a 2 stroke .....
Yea , the way you first explained it , I was expecting a hole in the case with a rod sticking out .... this is minimal damage , and wont affect anything running wise ..... I would replace Crank , ALL Bearings , Piston , and anything else obviously damaged , and do at least a timing chain , and a new gasket set ,and go ride .....![]()
