My bike has a FMF Q4 and has already been jetted for that muffler and airbox mod. I'm rebuilding the carb with a All Balls Carb kit. Is it OK to just use the jets that were in the carb if they have been cleaned? They all look open though some needed cleaning. The needle looks good and does not show wear that I can see - though it is my first carb rebuild!
Also, is it necessary or advisable to use the All Balls Mid-Body Gasket Kit? https://www.allballsracing.com/26-1510.html
The tops of the allen bolts that hold the mid-body casting onto the main casting seem to be filled with something like an epoxy or sealant. I'm worried about stripping the hex heads - and opening that can 'o worms..So, is it recommended to replace the mid body gaskets if you are just cleaning and rebuilding the rest of the carb?
I also have the CRFs Only Accelerator Pump Kit on order so I'm replacing that as well.
Do you think I should spend the time to check the valves if the bike was starting/running until it sat for 3 months?
Thanks!!
