throttle sticky?
  • stan3535
    throttle sticky?
    by stan3535 » Sun Nov 10, 2019 12:05 pm
    I put in a new throttle grip assembly and it doesn't want to snap back to neutral as quick as my friends bikes. The grip end is cut and free of any rubbing. Is there any adjustments I need to do with the two cables coming out of throttle? What are some tips to help the throttle snap back to neutral quick. Thanks!
    Re: throttle sticky?
    by JimDirt » Mon Nov 11, 2019 10:02 am
    It could be the throttle housing itself , sometimes if you tighten the top bolt it will bind ..... Try loosening the 2 bolts and see if it free's up , if it does then that is the issue and you need to tighten the bottom one then just snug the top , or try tightening them both evenly .......
  • stan3535
    by stan3535 » Fri Nov 15, 2019 7:23 pm
    Thanks so much Jim. that fixed it.
    by JimDirt » Fri Nov 15, 2019 10:15 pm
    No problem , Glad I could help ... ;)
