Chain sitting high on sprocket teeth
  • Palermodude
    by Palermodude » Mon Jun 12, 2017 5:30 pm
    Hello everyone- just bought a 2006 CRF230F and I immediately changed the oil and adjusted the chain which was too loose. Tightened it up using the snail adjusters and have both clicked at 33. The chain seems to be sitting a little high on the rear sprocket despite the right amount of play in the chain. Just wondering if this is normal or if I need to alter it. Thanks!
    [URL=https://imageshack.com/i/poHKLd42j][IMG]http
  • Palermodude
    Re: Chain sitting high on sprocket teeth
    by Palermodude » Mon Jun 12, 2017 5:35 pm
    by JimDirt » Mon Jun 12, 2017 10:52 pm
    It looks like the chain is stretched , the only "fix" is to replace the chain AND sprockets , since a stretched chain will wear the sprockets abnormally and if you just replace the chain , it will wear out quicker than normal , and wear the sprockets even more , as you can see the "curve" in between the teeth is oblong , which means everything is toast , unfortunately , due to a lack of proper maintenance by the prior owner , its going to cost you a little extra for your new bike ....sorry.... :(
    by Aussiecrf230 » Tue Jun 13, 2017 12:17 am
    Spring for new sprocket bolts and nuts with the new sprocket. Keep the old ones as trail spares if the heads and threads are in good nick. There is never a good result if the sprocket comes loose from old bolts. Use a torque wrench on them and check them after a bit of riding. Enjoy they are a great bike!
  • Palermodude
    by Palermodude » Tue Jun 13, 2017 7:23 pm
    Thanks for the input guys- I will be getting a new front and rear sprocket as well as a new chain and bolts!
    by Aussiecrf230 » Wed Jun 14, 2017 4:12 am
    Stay with the 520 chain they do last longer.
