Crf450r clutch problem,any info would be appreciated
Posted: Thu Sep 08, 2016 12:33 pm
by Russ kwondo
Hi everybody, got a problem with my clutch :(, it worked spot on when i last used my bike which would of been February,its been sitting in my garage since then unfortunately from not having time to use it but got it out last weekend to kick it in and run it down my alley which is about 100 yards and the clutch just doesn't work at all,could it be because its been sitting in a garage for months or is it done in,thanks
Posted: Fri Sep 09, 2016 4:35 pm
by treeruns
Had similar event, did you check the oil? Add a little warm up bike and try again.
Posted: Sun Sep 11, 2016 9:25 am
by Russ kwondo
Never checked the oil lol,i will check it and see,it hasn't been changed for a while either,thanks
Posted: Sun Sep 11, 2016 9:26 am
by Russ kwondo
treeruns wrote:Had similar event, did you check the oil? Add a little warm up bike and try again.
Posted: Sun Sep 11, 2016 9:59 am
If you think that the clutch plates are stuck together. Not all that uncommon and not a cable problem. Then you can drain the oil & use 1 qt. ATF in the trans. Let it soak a day or two then run the bike while working the clutch lever. That ATF will clean and free up the stuck plates.
Hope that helps.
Posted: Tue Sep 13, 2016 6:18 am
by Russ kwondo
Cheers will do,i think last time i changed the oil i put the same in both sides,is this bad?
