450 cylinder-will it fit?
    momuzik
    by momuzik » Wed Mar 30, 2016 3:23 pm
    ok you CRF450 experts, will a 03 cylinder work with a 06 bottom end...thanks in advance
    by JimDirt » Wed Mar 30, 2016 6:26 pm
    It should , all cylinders are the same as far as i know , the heads will bolt on but cam decompression systems and towers and have to be swapped as units , and valves are different sizes between years , but yes you can put a 03 cylinder with a 06 bottom end and head , unless there is something i don't know about
    You could PM Ken , he can say 100% what will/won't fit , but i am pretty sure you should not have any issues between 02-08 cylinders and cases
    momuzik
    by momuzik » Wed Mar 30, 2016 8:00 pm
    ok thanks Jim, much appreciated, that helps alot much appreciated and yes Ken is such a guru (y)
