JimDirt wrote:The air filter can be a issue , especially if it was running fine before hand , a overly oiled filter will cause a rich condition , did you try starting it with the Hot Start lever pulled ?? , if it starts or tried to start when using it , then the issue is a rich condition
A way to test if it is a lean condition is to remove the spark plug and dip the electrode part in gas , then reinstall the plug , and boot , and try to start it , if the bike starts or tries to , then its a lean condition , these quick tests will at least narrow down your issue
When you say the jets were not clogged (Pilot and main jet) , how did you actually determine this ?? , a Pilot jet can still be clogged even if you can see thru it with a light , , also , you did not mention anything about the Fuel Screw , have you tried adjusting it ?? , in the inspection of the carb when you took it all apart , did you confirm that the O-Ring , washer and spring were intact and in the correct order (from tip it should be O-Ring,Washer,Spring) , a torn or damaged O-Ring can cause a massive lean condition , did you confirm the Hot Stat is working properly and was not stuck inside the carb ? , did you confirm the Floating Slide Plate Seal is intact ??
JimDirt wrote:You should still go ahead and replace the pilot jet if you get the chance , unless you get the carb cleaning tool , the pilot jet is fairly cheap (at least it is in the states , not sure what parts cost over there) , it does not take much debris to clog them , even if its slightly clogged it will cause issues , i always have a few extra lying around as well as different main jets , just in case .... but glad its running !!
JimDirt wrote:This is a basic jetting guide , you should be within this range
Jetting Guide for Main Jet:(pilot 45) CRF450R/X
:*: Elevation is measured in "Feet" Above Sea Level , you might have to convert to your measurement system , Temp is also in "Fahrenheit " , not Celsius :*:
Sea level....165
2000 ft.......162
4000 ft.......160
6000 ft.......158
8000 ft.......155
Temperature/Elevation:
Also , on the squirter , its just missing the slide correct ?? , you do not want it hitting the slide if it does you have to adjust the AP timing accordingly , usually the bog is caused by AP timing , unless your jetting is way off
Fuel Screw should be between 1-1/4 to 2-3/4 , if its less than 1 turn out (need smaller pilot) or more than 3 turns out (need larger pilot) , you will need to change your pilot jet accordingly
Also , what clip position (from the top) is your needle clip at ?? , it should be 3rd or 4th (usually 4th works best)
