by JimDirt » Tue Mar 24, 2015 2:29 pm
Go up 1 on pilot , to a #45 , that should get rid of the lean condition on the bottom end , and get you back to 1 1/2 but without the popping
BUT
Make Sure your intake valves are not tight , they can give some of the same symptoms , you did not mention if you checked them when i asked
Also make sure the header to head connection is tight/sealed properly , as well as the mid pipe connection , any exhaust leak can cause it to suck air and backfire/pop thru muffler , acting like lean jetting
