2009 150r - how to remove water pump impeller?
  • grxog
    by grxog » Fri Dec 05, 2014 6:10 pm
    150r needs the impeller shaft seal replaced due to leaking coolant out of the weep hole. I removed the water pump cover to find the impeller. I tried to remove the impeller, but whne i turn it it also turns the engine. I say on a video to hold in the clutch while turning it but it doesnt work.
    How do i remove this thing?
    Thanks, grxog
  • Tm85cc07
    by Tm85cc07 » Sun May 15, 2016 7:24 pm
    Was the bike in gear? Also not sure on your bike but I know a lot are reverse thread
    by crfsonly » Wed Jun 01, 2016 3:27 pm
    Here's a water pump rebuild kit:
    http://www.crfsonly.com/catalog/product ... ts_id/5900
    Ken
