To post a pic , you need a hosting site like Photobucket or Image Shack (what i use) , you make a account , upload your pic to it , then get the link to the image and copy/paste it in your post
My 450X is still on the original bottom end , no issues whatsoever
Doing it yourself , all you need is the crank kit , gaskets and flywheel puller and depending on how many hours/miles are on the top end , you might consider freshening up the top end (depending on your budget) while you have the entire engine torn down , though to do the top end you dont have to pull the engine , so you can do it at a later time if you need to , doing the crank you have to pull the engine , so while its out , its just easier to do it , so its up to you and your budget
Prices will vary , but doing it yourself you will only be out parts , so a huge savings in labor costs , it will be a few/several ($250-$700) hundred depending on where you get them , compared to $1500 - $2500+ for parts and labor depending on what you have done , Ken sells everything you need here , or you can go to eBay or anywhere online and get the items you need , then you will need your oven to heat the cases and your freezer to cool the crank (so the bearings slip into the case easily) , and slap it back together and ride (not literally)
http://www.crfsonly.com/catalog/index.p ... /2a/page/4
