by JimDirt » Wed Oct 01, 2014 2:02 pm
There are also issues if the bike was laid down (in a crash) and left laying on its side or slightly upside down if laid down on a hillside , for more than a minute oil so , it can let oil build up in the valve cover , then drain from the valve cover breather and drain into the airbox via the breather hose , so that is another possible cause for the oil , but as Ken stated , try to locate the oils origin , clean everything up , and see if it happens again , then try to trace the route
