Weird noise, need help!
  • R3COIL
    by R3COIL » Fri May 09, 2014 10:24 am
    Hey guys, i have a problem with my 2004 crf250r. It makes a weird noise while riding on trails or up a road and i can't figure out if its my chain or my valves chattering. This is my first dirtbike and little things worry me. I've changed the oil and filter, looked at the valves and they were all in spec. The only way to describe it is a clacking or clicking noise. The front sprocket is pretty worn so i just don't know. I was riding with a friend and he noticed the noise when i took off at a super slow speed and when i was slowing down. Any help is greatly appreciated. :/
    by crfsonly » Fri May 09, 2014 12:05 pm
    check your auto decompression system. often some oil or very light coating of very thin assembly lube will help. i recommend replacing the spring as a maintenance item.
  • R3COIL
    by R3COIL » Fri May 09, 2014 1:52 pm
    im checking my valves tomorrow while i wait for my front sprocket and clutch cable to arrive. i dont have a manual so im limited to what i can do confidently. ill try though haha.
    motosicko
    by motosicko » Sat May 10, 2014 6:02 am
    Replace both sprockets and chain as a set. If your front sprocket is worn, so is the chain. The chain pins wear thin and the bushings around the pins will make noise as they rattle.
    "There are old racers
    and there are bold racers,
  • R3COIL
    by R3COIL » Tue May 13, 2014 1:24 pm
    Thanks motosicko. I ordered a new front sprocket because the rear is fairly new, only two seasons here in maine on the sprocket but the front sprocket was stock though so it looks like hooks lol. I'll have all my parts tomorrow so i'll install my clutch cable and the sprocket, tighten my chain a bit, if that takes away the noise i'll order a new chain.
  • dlee
    by dlee » Tue May 20, 2014 6:31 am
    Hey Ken,
    It there a write up on how to properly adjust your decompression set up for easier statrts
    Thx
    Dan
    I didn't vote for him
    2005 CRF450X
