hall_philip wrote:thanks ken, I had already referenced that, but when I go to grind them will I be taking it to the exact specs in the book of is there a tolerance? and since this is the piston that Honda had installed, did they fail to check the specs?
my apologies for not reading carefully your question. review the service manual at the begining of the Cylinder/Piston chapter for Piston Ring End Gap. It will have the "standard" gap range specs and the "service limit" spec. for the '09 they are:
Top Ring: Standard: 0.15-0.25(0.006-0.010) Service Limit: 0.39(0.015)
Oil Ring: Standard: 0.20-0.070(0.008-0.028) Service Limit: 0.90(0.035)
So, you want to gap them in the standard range and if the gap exceeds the standard range you would replace them on or before the gap reached the service limit.
Hope this helps.
Ken
