I think they are used on side covers?
Also, I need the pictures of bolts, nuts and screws holding those front-rear plastic frames.
Thank you.
Uploaded with ImageShack.us
The bike came from US too. Will check those u have mentioned all. Thanks. I have an OEM pipe on bike. Weirdo....riddler9 wrote:Interesting. Does not look like a factor bolt, or at least a bolt we see on the US bikes. The only 12mm of similar length that I can think of is the exhaust mounting bolt. Do you have a factory or aftermarket exhaust?
If you only took off the sub frame, absent the fender and airbox which use 8mm bolts, you are looking at:Front sub frame pivot bolt
Bottom sub frame to frame bolts (2)
Muffler mounting bolts (2, different lengths)
Side plates
Seat
Exhaust mid-pipe clamp (if you took the mid pipe off the header)
Upper and lower shock bolt with nut (bolts do not have normal heads)
Do you have bolts for all of these? None of these has a factory bolt like the one you are showing, and only some have a 12mm head. Still, some people will grab whatever fits - some will even use a 12mm hex bolt that has the same thread as the 8mm that came out of the hole. I think at this point you need to go through the process of elimination. Maybe post photos of what you still have apart?
