Aj1705 wrote:Hi,
I was out on my CRF 250 X yesterday, riding a local track. The bike was running spot on, no coughing or farting or anything didn't miss a beat. i came off the track cut the bike out and put it in the van take take to the jetwash, washed it off and tried to start it. to all i got was backfiring and popping. i have taken the top of the engine off exposing the cam, and there is no clearance on the exhaust valves, (if that is the ones by the spark plugs) and too much clearance on the cam lobes. Please help.
Aj1705 wrote:Thanks ken.
What is the spec for a factory standard piston?
Also, air filters dead as well as there was grit in the engine and all over the air box behind the filter.
The ring gap was way too big, but the bore is not scored or damaged. All parts from the bike are goin to be cleaned and inspected tomorrow for further signs after cleaning.
These engines arent actually that hard to work on, I'm a car mechanic but this isn't too bad considering ive never worked on a bike before. Main thing I've found take it SLOW and mark everything.
Thanks for help everyone will keep you updated
