ok.crfsonly wrote:welcome to CRF's Only! ok...i'll voice what you already know...to fix it right you need to replace the shaft. on a scale from 1-10 how helpful was that suggestion?really, you just need to replace the shift shaft. this happened to me on a XR400 and i bent it back well enough to be used but then one day some 30 miles from the staging area the shift shaft broke off. i was stuck in 1st gear for 30 miles. in the end had to replace it anyway.
again, welcome.
