Right hand turns
    coljam
    Right hand turns
    by coljam » Mon Jun 26, 2006 10:52 am
    I was riding on some sandy/gravelly trails this weekend. All the corners tended to be wide & flat. I noticed that I felt very confident in making LH turns -- left foot out; dragging rear brake slightly and plenty of throttle.
    However, on the RH turns, I felt significantly less confident. Found myself slowing down way to much before the turn to avoid the sensation that the bike would wash out.
    My question: What is the best technique for making RH turns on wide, sandy/gravelly flat corners?
    Thanks for the help.
    edelnero940
    by edelnero940 » Mon Jun 26, 2006 11:46 am
    what i tend to do on flat corners is come in to the corner braking as late as possible with the back wheel, blip the throttle once to loosen the back tire, and power it around the corner in a controlled drift. It keeps your momentum while still allowing you to control your bike around the corner. It can be difficult to master but its a great technique when perfected. Easiest technique however, is to come into the corner, keeping your weight on the pegs, getting as close to the tank as possible. You have to trust in your tires. Just keep working on your method until you perfect it. Also, try not to brake during cornering. Its best to brake before you enter the corner.
    '06 CRF230F
  • Hondaguy
    by Hondaguy » Sun Nov 19, 2006 6:14 pm
    hey i got the same problem on the right turns, i got no problem with the left turns. i think the advice just given by edelnero was some good stuff.......Thanks
    allvol11
    by allvol11 » Thu Dec 28, 2006 2:29 pm
    for some reason its the exact opposite for me im comfortable on rh turns but not on lh turns
    2006 450R - Mine
    Boyseen water pump
    K&N Air filter
    EVS Body Armor (trust me it works)
    2006 - CRF250R - Son
    2005 - crf50 - daughter
  • Hondaguy
    by Hondaguy » Thu Dec 28, 2006 2:51 pm
    hey by chance are you left handed? I think the majority is right hande3d and was wondering if that had something to do with it..........Don
  • johns230
    by johns230 » Sun Jan 21, 2007 9:23 pm
    I am by no means 'qualified' to answer this question by have tons of experience but here's something that I found that helps me greatly.
    I found the same problem with me and right turns until I applied some of my street experience. I used my eyes and relied on them. The last few times I've been out in the dirt I've been concentrating on my eye taking me where I want to go. It helped my right turns like you wouldn't beleive.
    Just my 2 cents
