Need some help with high siding.
Posted: Sun Jul 13, 2008 8:43 am
by djh65
So last year my son and I were riding on a lake bed. It was really slick and muddy. I was working on my sliding but found when I got around too far the back tire would catch and launch me. This was no big deal as we were riding on mud. So 3 weeks ago I was on a blue groove fire trail. Coming about a turn about 20 mph and the back tire started sliding. I did my best to steer into it with no luck. I got a quick trip to the ground with a torn ligament in my ring finger and a pretty bad concussion. Anyways my question is this. What do you do when the back end gets too far around?
Thanks,
David
Posted: Sun Jul 13, 2008 11:39 am
by ThumperX
Clutch it.
Posted: Sun Jul 13, 2008 12:51 pm
by Just me
Stop the swing before you get to full lock or you are going down. Roll out of the throttle or clutch in.
Posted: Sun Jul 13, 2008 1:41 pm
by djh65
it came around so fast. I got off it but it kept sliding.
Posted: Thu Jul 17, 2008 5:23 pm
by ThumperX
At that point all you can really do is tap the rear brake if possible otherwise your getting dirty.
Posted: Thu Jul 17, 2008 8:01 pm
by topgun
Depending on speed and terrain I would be leaning it over more to counteract possible highside and steer with the throttle
Failing that try strightening the bars - sounds weird but if you can get the front wheel going sideways a bit as well then no high side but you need a bit of room as you will be in a semi controlled sideways drift
Posted: Thu Jul 17, 2008 8:56 pm
by djh65
after giving it lots of thought the skid mark was only about 10 feet. The time to make some sort of correction was not really there. It was slide slap. Oh well
Posted: Thu Jul 17, 2008 10:49 pm
wish i could help you...but high-siding is how i shattered my tail bone...so i would only be able to help you high-side in spectacular form!
Posted: Fri Jul 18, 2008 8:31 pm
by djh65
My girl friend she said she wished I had my helmet cam on it would have been a mountain of plastic bits but the card would have showed it all. Geee thanks. lol
David
Posted: Sat Jul 19, 2008 8:27 am
by Trogdor
topgun wrote:Depending on speed and terrain I would be leaning it over more to counteract possible highside and steer with the throttle
BINGO!!! We have a winner!!! Here's a pic of Gene Romero showing proper execution of the technique:
Posted: Sat Jul 19, 2008 8:29 pm
by woodsman
I'm still trying to learn how to throw around a 450, but I'm learning on a little xr100 in a very dusty flat track. Try a smaller bike that you can control no matter what. I can break the rear wheel lose on that thing in 4 gear, and its geared pretty tall. It was really scary the first few times, but that pic above is dead on. Try sliding in sand also.
Posted: Sat Jul 19, 2008 9:00 pm
here's a tip...it's less painful to lay it down than to high-side. so, keep the bike low and throttle control is critical...if you get into the throttle too fast or hard the back end will come around and then it's over.
Posted: Sun Jul 27, 2008 3:19 pm
by WFOWOODS450
wanna stop high siding? stop quickly closing the throttle!!! if u stay in the gas and even give it more the tire will lose traction and the bike cant high side. Worse comes to worse u low side and get back up. your biggest mistake is getting out of the throttle, the bike is immediately going to hook up and launch u like a rag doll.
