Installing K&N filter on 2005 fiddy
  • mook929rr
    by mook929rr » Tue Jan 04, 2005 2:34 pm
    I installed a K&N filter on my new '05 fiddy, and when i removed the stock air box, it has a line running out of it that leads down into the case. When the bike is running, it feels like air is blowing out of this line, not sucking. Is it ok to get rid of this line and leave it unfiltered? Im not sure what the heck else to do with it... :?:
    2000 R/W 929RR
    2001 CR250
    2005 CRF50
    by crfsonly » Tue Jan 04, 2005 3:53 pm
    from your description it sounds like the crankcase breather tube...and you should definitely keep it and keep it filtered. UNI and K&N make filters for these vents.
    good luck!
  • 50's_all_the_way
    by 50's_all_the_way » Sat May 28, 2005 11:51 pm
    where can i get one of those filters ive looked everywhere and no one has any!
    :twisted:
  • krylon
    by krylon » Fri Jun 24, 2005 6:39 am
    Uni's filter is Part# UP-121
    Most any on-line 50 shop will carry something that will work. Applied has one too... Or go to your local lawnmower store and see what small filters they have for a 5/16" vaccum line.
    Mike
  • puff336
    by puff336 » Fri Jun 24, 2005 12:30 pm
    I just did the same thing. Went to Advance Auto and picked up an in-line fuel filter for a lawn mower. It fits the hose perfect, has an internal paper filter and only cost $1.97. I went ahead and sprayed some filter oil in it just in case...appears to be working fine and like you said except for start up and shut down it is blowing air out continuously so this should be able to trap any dirt that might be sucked up during starts and shut down.
