raised the clip and now throttle won't work?
  • DocCRF-X250
    by DocCRF-X250 » Mon May 18, 2009 4:33 pm
    I raised the needle on my sons crf 70 and now the throttle won't work when I screw it back on top of the carb? It works fine before screwing it in? Is there something I am not doing or a trick to get this right?
    '04 250 X-- Air box open, JD Jet Kit, FMF Ti Powercore exhaust, Twin-Air Power Flo Air filter, AP Mod
    '07 CRF 70 (sons)--Pod air filter, opened exhaust and re-jetted
    amaviper
    by amaviper » Mon May 18, 2009 4:57 pm
    What is the throttle doing? Won't open or opens and won't drop back down? Does the slide go to the bottom of the barrel?
  • DocCRF-X250
    by DocCRF-X250 » Mon May 18, 2009 5:39 pm
    once I screw it on the throttle is stuck at about 1/4 throttle and it won't release when I turn the throttle it does not do anything to the throttle cable? It works perfect when it is not screwed in. Could the throttle cable be getting stuck in the spring perhaps? I guess it opens but does not drop down?
    amaviper
    by amaviper » Mon May 18, 2009 6:10 pm
    Do you see about a 1/4" of the barrel after you drop it in? You might have the slide turned 180 degrees.
  • DocCRF-X250
    by DocCRF-X250 » Tue May 19, 2009 5:42 pm
    I tried tonight and the barrel was not going down i did turn it and everything is perfect now. Thanks for the advice!!
    amaviper
    by amaviper » Wed May 20, 2009 6:42 pm
    Glad I could help
