not much twist on the throttle
  • pquirk
    by pquirk » Fri May 01, 2009 1:38 pm
    This may be a commonly asked question but I searched and didn't find the answer, maybe I'm not using the right words? I got an '07 CRF50 for my boy and it seems like the throttle throw is REALLY short. It goes from fully closed to fully open in about 1/8th of a twist of the grip. Is that normal for these bikes? I bought it "newish", but it was a demo that had been used on a tot track at a bike expo so it could have been messed with. I've got manual ordered, but I'm hoping for some quick info so I can get him on it with confidence. It seems it'd be difficult to modulate the throttle much with such a short throw. Yes, I did adjust the limiter to fully open.
    2005 CRF250R
    amaviper
    by amaviper » Mon May 18, 2009 5:00 pm
    Not normal. Check to make sure somebody didn't put a tube or shims on the cable by the slide. Should be able to tell what is going on by pulling the slide and working the throttle.
  • rocketman
    by rocketman » Wed Nov 04, 2009 1:16 pm
    There is a thottle lock screw on the back side back the screw out to get more throw
    amaviper
    by amaviper » Wed Nov 04, 2009 10:36 pm
    He did state "Yes, I did adjust the limiter to fully open".... back in ... May :shock: :lol: :lol:
  • rocketman
    by rocketman » Thu Nov 05, 2009 8:47 am
    O-weel, guess I picked up an old thread, But it sure sounds like he went the wrong way on the throttle stop.
    IamTheCowboy
    by IamTheCowboy » Wed Nov 11, 2009 1:50 pm
    If you remove the throttle stop altogether, you will know if that is what is causing trouble.
    04 250x
    Scotts Damper
