by Asmith » Sun Mar 30, 2008 8:23 am
The stock CRF70F has a 62 main for it's tiny 17mm carb and you most likely do not need to rejet.
Mess with the mixture screw, start at 1.5 turns out. They run fat stock.
If you must rejet try the next size bigger, a 65.
Try the needle first.
If it has grooves, drop the clip one position.
If it does not have grooves, shim it 1mm with a shim from Radio Shack.
