Handlebars
    zuma711
    Handlebars
    by zuma711 » Tue Feb 27, 2007 7:55 am
    Quick question, how is the best way to straighten handlebars or do I need to replace everytime the boys bend them? Daddy ain't made out of money! :?
    KevinM
    by KevinM » Tue Feb 27, 2007 1:50 pm
    If they're riding it so hard that they're bending the bars... I honestly would be concerned that I wouldn't be giving them a lined up front end if I tried to straighten them. Though I've been told steel bars can be straightened to some extent.
    But I think it depends upon how bad they're bent. If the bars are creased, I'd say they're trashed. If you have to straighten them more than once, I'd be concern that they're fatigued.
    Post a picture.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
    zuma711
    by zuma711 » Tue Feb 27, 2007 2:30 pm
    The bends are not bad, mostly from laying them over at low speeds. They have no creases or cracks just not completely straight?
  • .sinner
    by .sinner » Tue Feb 27, 2007 4:41 pm
    If there not severly bent just leave them alone. They'll get used to it :lol:
    KevinM
    by KevinM » Wed Feb 28, 2007 6:54 am
    You could probably tweak em back into form then.
    Maybe get a longish pipe big enough to fit over the ends. Like may 1-1/2 or 2" dia. See if you can slowly get them back. You should be able to leave the left grip on... but take off the throttle assembly. Good time to clean under the throttle anyway. Dirt gets in there and makes the throttle gritty.
    Go slow though. Be careful you don't make it worse.
    G/Luck.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
    zuma711
    by zuma711 » Wed Feb 28, 2007 7:28 am
    Thanks I may try working on them tonight....
    Thanks for the comments.
  • cruisers450
    by cruisers450 » Wed Feb 28, 2007 8:04 am
    i put a red baron clamp and bigger bars on my daughters bike.
    NCLR1
    by NCLR1 » Tue Mar 06, 2007 1:56 pm
    Are the bars actually bent or is the front tire tweaked inside the forks? My son tweaks his all the time and looks like the bars are bent. Try loosening the 2 bolts that are half way down the fork tubes and kick or push the tire over a little and check how that does. It helps to take the front fender off so you can see the tire while you do this.
    Tony C
    mr50
    little red
    by mr50 » Tue Mar 06, 2007 5:08 pm
    :D that is one of the coolest little bikes i have seen were did you get the red tires and the decals
