Numbers
  • Jason
    Numbers
    by Jason » Wed Jan 19, 2005 1:47 pm
    There's a race coming up in a few weeks I'm going to enter. I've never done this before and was wondering if you can just put any number on your bike or do you have to get one assigned to you. I was thinking that you only had to register your number with the AMA if you were racing in Nationals or Pro. I don't want to put some on and have to change them later.
    Gravity is the only reason I have scars.
    2005 CRF 250R Twin Air Filter W/Sealing kit-JD Red Needle 5th Notch-175 Main Jet-Boyesen Acc Cover- JD Power Surge
    1971 Zuki 185
    by crfsonly » Wed Jan 19, 2005 5:35 pm
    jason...it depends. i race at Glen Helen and it's pretty much run with whatever you like...unless someone else has already registered with that number....then it's electrical tape time!
    you should check with your local track for specifics...
    good luck in your race and definitely let us know how it goes.
  • Jason
    by Jason » Thu Jan 20, 2005 9:18 am
    Right after posting the previous I found that it's just run what's on your bike and hope nobody with the same number registers before you. There's two races on the same day. One at the club and the other part of the Honda of Houston series. I might just run the one at the club seeing how it might be easier for me and not as intimidating. I have a month to figure it out.
    1971 Zuki 185
  • crf_rider.com
    by crf_rider.com » Tue Jan 31, 2006 10:30 pm
    watch at you local track for different numbers then buy 1through9 and three packs of each. then you don't have to worry about anyone having the same numbers
    Crf250R
    run um hard run um stock
