2008 CRF450 1/4 Turn Throttle
  • 08ISGR8
    by 08ISGR8 » Sat Jun 12, 2021 9:05 am
    Just wondering what the best options would be to reduce the amount of throttle turning would be on my 2008 CRF450.
    I am finding it hard to hold a proper arm position and hold the throttle where I need it to carry speed over ramps.
    Any input is appreciated.
    Thanks
    Re: 2008 CRF450 1/4 Turn Throttle
    by JimDirt » Sat Jun 12, 2021 1:38 pm
    What bars do you have on it ?? , and are they in the forward or rear position ??? , are you over 6 ft. tall ?? , are you exceptionally short ?? , what exactly is the issue ?? ........ Are you getting arm pump ?? , are you getting sore wrists ?? ....... A bit more detail as to the actual issue and your setup might help decipher the issue ..... the downside to quicker throttle on a 4 stroke is torque , you get way more torque than you really want , then it makes you hold on tighter , then you get arm pump , or numb hands , or just tire more easily , making blood flow reduced , which makes for more arm pump and numb hands ....
    Not sure what the goal is ..... but 1/4 turn throttles are out there , it is just a question of if that will solve your issue
    Also , what position are your levers in ??? , if they are straight out , you will have loads of issues , especially if you stand a lot and especially if you stand , and you are tall ..... , I am thinking this is more of a setup issue than a throttle issue
    I am 5' 9"ish , my levers are around the 7 o clock position , / , <<< like that , I stand the majority of the time and I also have a severely damaged wrist that does not bend at all (clutch side , luckily) , so I can't bend my wrist up/down , so I keep both my levers the same and it makes for easy riding , the only arm pump I get is from the 60 hp my bike puts out ..... I ride moto and off road (2 different bikes , and have them set up pretty much the same as far as ergo's go ... , makes it fluid to transition from one bike to the other , no adapting at all , just get on and ride ....
    by Aussiecrf230 » Sat Jun 12, 2021 4:24 pm
    A 1/4 turn throttle sounds like it would make it to touchy especially in the rough.
  • 08ISGR8
    by 08ISGR8 » Sun Jun 13, 2021 7:00 am
    The problem I want to fix is I need about 20% more throttle with the wrist articulation I can comfortably get.
    I don’t exactly need to get a 1/4 turn throttle but I do need a little more than what I have currently.
    I’m pretty out of shape honestly. I know I should be standing around the majority of the track but I can’t.
    My wrists are fine id say but I also can’t hold on to the bike anymore after about 3 laps.
    I just assumed 1/2 my problem is that I need to do some conditioning work unrelated to the bike. But if you have any suggestions to help I’ll take those also
    My levers are a little high from what I like and I will be adjusting them lower next time out. Maybe that will help with the overall grip on the throttle? I guess I never thought about it that much. I’d say they are at about 3:00 (facing straight out or level)
    by Aussiecrf230 » Sun Jun 13, 2021 8:01 pm
    I have tended to ride mostly sitting so line up the levers to be opposite side in line with my arms so probably 4-5 o'clock looking from right side of bike.
