I have an 05 450 x and I’ll try putting that in. I used a digital volt meter and had 13 volts from the battery and the connector behind the plate at 12. I thought it was the estart button because it rubbed through the wire. But what are the chances of it being the sensor wire?Welcome to the site Bhinkle,
Does it have power at the solenoid to operate the starter?
What do you have to test the circuit. A digital volt meter may show good voltage but there may be insufficient current to activate a solenoid. Hence no click at the starter. This could be caused by a bad connection or flat battery.
Have you tried supplying power straight to the starter to confirm it operates. Then do the same with the solenoid. This will help narrow down the problem.
