Quick question - trail tech flywheel
  • Got-Beef
    by Got-Beef » Sun Apr 17, 2016 1:39 am
    Been offered a trail tech flywheel
    It's a 6171 - 35 . A 35 oz for a 06 upwards crfx 450
    I'm just trying to find out if this will fit a 2005/6 crf450r with a lighting kit installed . As the serial numbers are different , but I didn't think the physical difference ?
    Appriceate the replys ,
    by JimDirt » Sun Apr 17, 2016 7:35 am
    As far as i know the X and R flywheels are not interchangeable , the crank itself has a different end on it , so the nut/shaft size is different , as well as the overall size of the flywheel and stator are different diameters , and the X stator would not fit in a R ignition cover *as far as i know* , R is only R and X is only X on Flywheels as far as i understand , the only ones it might fit is 09-12 (maybe) because the crank end/nut is the same as the X (the X and 09-12 R use the same flywheel puller , the 02-08 R use a different puller)
  • Got-Beef
    by Got-Beef » Sun Apr 17, 2016 10:45 am
    Ok
    Great Thanks for the reply jim
    I'll just buy the dedicated one for my model from crf's instead
