JimDirt wrote:Welcome to the site !!
Have you done any kind of service on the bike yet ?? , like check the valve lash , FRESH gas and draining the old (if it sat for more than a month , the Ethanol in the gas could have clogged the pilot jet) , does the bike pop thru the muffler after it is running ?? , does it pop heavily on deceleration ?? , if so this could indicate tight intake valves or a clogged pilot jet
Sometimes a certain starting procedure is needed when cold , this is the case with my 450X , so try this
Turn on gas , and pull choke
Twist the throttle 4 full twists/snaps
Push down on the kick starter , and slowly go thru the stroke till you feel the compression (it will start to get harder to push) , then bring the kick start all the way up , and give a FULL FIRM kick , putting your weight behind it (don't try to start it like a 2 stroke)
It should either start or TRY to start , if it tries , then repeat the procedure , it should start within 1 to 3 attempts at this while cold
If it does not even sputter , then you need to do a check thru what i mentioned before , checking valves , and pull the pilot jet and see if its clogged , check the hot start function , make sure the lever works properly
JimDirt wrote:Keep us informed on your progress , a #45 pilot jet should be good under most circumstances , you "should" not need larger , if it has a $42 then the #45 will be fine
Here is a jetting chart to follow
Jetting Guide for Main Jet:(pilot 45) CRF450R/X
Sea level....165
2000 ft.......162
4000 ft.......160
6000 ft.......158
8000 ft.......155
Temperature/Elevation:
JimDirt wrote:lol i was editing when you posted , so read the added info at the bottom .....
JimDirt wrote:That is WAAAAY to big of a Pilot jet no matter the temperature or elevation , what is the setting on the fuel screw ??? , it should be between 1-1/4 turns out , to 2-3/4 turns out , no less , no more , a pilot jet that large would indicate a major vacuum leak , or a major clog or air leak in the carb
a 50 , is just not the correct "fix" for your issue , there is something else you are missing
When its 20 here , i can fire my bike up within 3 kicks with a 45 pilot jet and a 160 main jet , i use the same jetting in the summer when its 100+ , and just lean out the fuel screw (in) , i also use Shell Rotella , but its full synthetic , and 5w-40 , and i have ran a 48 pilot jet , but i was at 500 ft elevation
You compensating for something else your missing , its either a fuel delivery issue (not enough) , within the carb , or its a massive air leak , (within the carb or exhaust system) , , or you have a issue with the timing being off , or your valves , you need to check the valve lash and see where its at , check the spark plug , as it could be going bad , or have too large of gap , but no matter what , your overlooking something here , and a 50 pilot jet , is not the answer ..... if you can turn the fuel screw all the way in , or more than 3 turns out to get it to run , then your jetting is not correct and/or you have a air leak , or blockage in the carb (or a timing or valve issue)
I understand your happy its running , but its not correct and needs to be addressed , you need to find the issue that is causing the need to over jet dramatically , 50 is just waaay to big , period....sorry
PM leardriver ,, he hangs out in the Jetting part of the forum , he is the resident carb expert here , and does carbs for a living , he will confirm what i am saying , but , he should be able to direct you closer to the issue than i can at this point
JimDirt wrote:The detriment is heat , a richer engine will run hotter than a properly jetted or lean engine (less fuel , less heat) , this is why you lean a engine in the summer and richen it in the winter , though not to the extreme you have , just a fuel screw adjustment and maybe a main jet change by 1 (up or down depending on temp) is all that is needed for most
Talk to leardriver , if anyone can pinpoint your issue he can(if its fuel related) , i would still check the valves and such , and just do a good go over of the bike/engine to rule out and narrow down everything
