110 Gas
  • 2005CRFMAN133
    110 Gas
    by 2005CRFMAN133 » Mon Jun 23, 2014 11:47 am
    My local gas station that has 93 none ethanal was closed so I grabbed some 110 race gas 3 gallons and then got 93 with ethanal 2 gallons and mixed. Is this bad to run in a stock engine also my bike is a 2006 completely stock!!!! Thanks for any and all input!!!!
    riddler9
    by riddler9 » Tue Jun 24, 2014 3:35 pm
    50/50 would be better. The whole topic is a bit of FUD. Just like automobile mfg's, modern bikes are made to run on 10% ethanol. Ethanol does add to carb maintenance, anything beyond is rare. Just stay away from E85.
    Will a bike run better w/o ethanol? Depends on the bike. Is a modern bike designed to run 10% ethanol, yes.
    Official Lurker
    by JimDirt » Wed Jun 25, 2014 1:23 pm
    To set you at ease , my 450X engine itself is stock with exception of HotCams Stage 1 , and Stainless intakes , my 450R engine is stock with the exception of Stainless Intakes , i run 1 gallon of 130 Octane Leaded Av Gas from the local airport , to 5 Gallons of Premium 91 Octane 10% Ethanol Unleaded
    My bikes run fine , actually cooler temps , and performance wise run better , so no worries , i have actually run pure Av Gas with no issues , and i find that it has way less carbon buildup on the piston and valves because of running it either pure or mixed ,and if the bike sits for a time it will still fire up with no carb crud buildup like usually happens with Ethanol crap gas
