crf450r running hott. leaking radiation fluid out over flow
  • kenny304304
    by kenny304304 » Thu Jun 05, 2014 2:42 pm
    I have a crf450r and it runs hot when I get on it. I can ride it maybe 10 minutes and starts running hot. It is also really hard to crank, but once its been cranked it easy to crank back up. When cold I have to kick it maybe 30 time before it starts. It also pops for the first minute after being cranked. Is there anything I can check to fix these problems? The carb. Has be re jetted and cleanded well.it leaks anti freeze out over flow hose. When it runs hot[/img]
    by crfsonly » Thu Jun 05, 2014 6:16 pm
    first, the starting issue could be the carb and/or tight valve clearances. check the clearances first. if they are good then you'll need to look into the carb (pilot jets, fuel screw, AP, and floating valve seal are typical culprits.)
    as for the over heating it could be a lean condition with your jetting, type of coolant you are using, head gasket, water pump or other issues. check your engine oil make sure it is clear and at the correct level. are you loosing coolant before it overheats?
  • kenny304304
    thanks
    by kenny304304 » Thu Jun 05, 2014 6:19 pm
    Yes it starts leaking out the over flow hose before it runs hot. I honestly don't know if its even running hot I just know it leaks out the hose after riding for a few minutes
    by crfsonly » Thu Jun 05, 2014 6:25 pm
    First, check all the hoses and make sure none are kinked or pinched off. If not, I'd drain the coolant and then pull the radiators and hoses and check for any obstructions in the hoses and radiators. If all is good then you should pull the water pump cover and inspect.
    Ken
  • kenny304304
    thanks
    by kenny304304 » Thu Jun 05, 2014 6:29 pm
    Ok great I will try all of this and get back to you.. thanks for the help
  • MikeOK
    by MikeOK » Fri Jun 06, 2014 5:58 am
    Start with the simple and try a new radiator cap. They are supposed to lose a little otherwise there would be no need for a drain hose. As for your starting, have you tried different methods of starting? I know on mine if you don't follow it's own particular drill it can be a beast to start, if you do what it likes it will start 1st or 2nd kick every time.
  • kenny304304
    thanks
    by kenny304304 » Fri Jun 06, 2014 7:48 am
    What do you do to yours to make it crank easy? After its warm it cranks 1st kick... I will try cap first though thanks
  • MikeOK
    by MikeOK » Fri Jun 06, 2014 7:52 am
    On mine the drill is to choke, give one twist on the throttle (two or three if it's cold out), and kick the snot out of it. I've had two of these bikes and they both had to be started completely differently. On the other one sometimes I had to drain the bowl a little to get it to light if it had set for a few days or more.
  • kenny304304
    ok great
    by kenny304304 » Fri Jun 06, 2014 7:55 am
    I will try that. My choke when I pull it though it goes right back in. Shouldn't it stay out? Maybe I need a new choke on it
  • MikeOK
    Re: ok great
    by MikeOK » Fri Jun 06, 2014 8:00 am
    kenny304304 wrote:I will try that. My choke when I pull it though it goes right back in. Shouldn't it stay out? Maybe I need a new choke on it
    That's most likely your problem then, try working it in and out a few times maybe your detention that holds it open is gunky. I'm not sure if there is a seal in there or not that holds it out but you should feel a solid "snap" when you pull it out.
  • kenny304304
    ok
    by kenny304304 » Fri Jun 06, 2014 8:02 am
    Awesome thanks for the help
