by JimDirt » Sat May 31, 2014 8:37 am
Sorry for not replying sooner , my internet was down for a few days
The springs might be the issue unless your a faster rider that can work with the stiffer springs , make sure your correct for your sag settings , and mess with the clickers , but having the bike sprung for your weight is pretty important to handling , if the front end is way too stiff , the bike will push in corners , try turning the top compression clicker counter clockwise 2 clicks at a time and try riding the same section and see if it gets better (it should)
You might be able to get by with the springs if you soften the clickers in the front , and turn the Low Speed Compression on the shock(the flat screwdriver slot on the canister on the right side just under the seat)clockwise 2 clicks at a time (testing between each time ) this will stiffen the rear a bit and soften the front putting more weight on the front end and allowing the bike to bite better in the corner , dont adjust both the front and rear at the same time , do one , then test ride , then the other then test , so you can tell what each setting is doing
If it does not get better then you might have to go to softer springs
See if you can get the suspension specs from the old owner (valving,fork main and pressure spring size , oil CC , shock spring , linkage , etc)
