Building up my CRF450R for Dual Sport/Street Legal
  • EndGame
    by EndGame » Sat Apr 19, 2014 6:12 pm
    Hey guys,
    New here and picked up a 06'CRF450R a few months back. Just getting around to going completely through her, and making it dual sport/street legal setup. It had a engine overhaul right before the guy sold it to me, so I decided to go through everything else and add som stuff from michilen ac10 tires, all-balls bearings, race-driven brakes, trail tech speedo/flywheel/stator, boyesen waterpump, baja design light kit, hand/brush guards, etc.
    I got the new flywheel and speedo on. Just waiting for everything else to get here.
    Here are some pictures of my handy work so far...
  • EndGame
    by EndGame » Sun Apr 20, 2014 5:21 pm
    I got a bit excited and ended up here, haha. I'm replacing all the bearings in it now too, ordered a Jagg oil cooler as well to get some more oil in her, and a high pressure radiator cap. So, the only thing left on the list of wants/needs is the larger fuel tank(around 3.5 gal) and some baja/dakar high capacity modded radiators.
    FYI, those wheel bearings are the blind type... So, I had to order a special puller for that. $40 for one on ebay, not to shabby.
    by JimDirt » Sun Apr 20, 2014 7:04 pm
    It looks sweet so far , its going to be a nice looking/riding bike when you get it done
    And i like your (350 Chevy block ??) bike stand !!
  • EndGame
    by EndGame » Sun Apr 20, 2014 7:38 pm
    Haha, it's a Chevy big block 396. Pretty much a boat anchor since the rear main seal lip is busted off. I've got a real bike stand coming though as moving that block around sucks! I had to pick it up by myself to get it in my trunk bringing it back from Nebraska. Thanks for the kind words though! I'm going to keep posting pictures of it all as it comes together over the next week or so.
    by JimDirt » Sun Apr 20, 2014 8:25 pm
    LOL , i knew it was a Chevy , i was just guessing at the size since i could not see all of it since it is partially covered by the ........ Cargo Shorts ??? :-k .... and plastic drop cloth ... ??? ....Ya gotta do what ya gotta do lol
    Keep the post updated with progress pics !!
  • EndGame
    by EndGame » Mon Apr 21, 2014 6:39 pm
    The Baja Design dual sport light kit came today along with the renthal chain, oil filters, tire changing lube, and tools. I got the front light mounted, but can't really do much more until more parts get here.
    2006 CRF450R
    crazybrother
    by crazybrother » Tue Apr 22, 2014 2:18 pm
    Hey, while your in there don't forget to clean and service your CARB. It will be much easier with everything off and out of the way :D
    Keep any eye on that Trailtech stator, they are known for failures...
    If it does give you any issues, check out the BD or Rickystator. Both are well known and reliable.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
  • EndGame
    by EndGame » Tue Apr 22, 2014 2:53 pm
    Thanks for the heads up on the stator. The engine along with the carb were overhauled right before I bought it, so I'm good as far as that goes.
    In other news more parts came today. The bike stand, Enduro Engineering handguards, and oil drain tub. I really like the handguards! These things are heavy duty!
    By the way, the Jagg oil coolers are not longer available... I guess I'm going to have to go a different route now.
    2006 CRF450R
  • EndGame
    by EndGame » Thu Apr 24, 2014 9:51 am
    I got a bunch more parts yesterday. I installed the stator in the cover, but couldn't bolt it all up because I ripped the new gasketjavascript:emoticon #-o. The gasket was vacuum sealed in the worst packaging they could've stuck it in. Just as I was thinking I was going to damage that gasket trying to get it out... I did. I wasn't really impressed with it's quality once I got it out, and just ended up tossing it in the garbage. Then I went upstairs and ordered a new OEM Honda gasket(should've done that in the first place). I also found a like new IMS 3.2 gallon tank for $150 on Ebay, so I snatched that sucker up. I'm really debating on buying a new wheel set for it too.
    2006 CRF450R
  • EndGame
    by EndGame » Thu Apr 24, 2014 3:28 pm
    More parts again today! The mounts for the mirrors came and I put them on. Mounted the new tire to the rear. I'm waiting on the new tube for the front, but I took the old tire off to have her ready. Installed one of the new brake rotors on the rear wheel too. The Boyesen water pump came and is now installed. That thing looks sharp, and will hopefully help keep her a bit cooler. Last thing I did today was drill the holes for the rear tail light assembly. It was a pretty straight forward install. Lastly, I'm set on getting new wheels in two months. These ones will just have to get me by for the time being...
    2006 CRF450R
    crazybrother
    by crazybrother » Thu Apr 24, 2014 5:06 pm
    So when your new tailight gets destroyed...(Mine did) Check these out:
    http://www.cyclegear.com/CycleGear/Part ... 771_202163
    It looks a whole lot better and also works much better too :D
    I do Love the look of that Michelin. :lol:
    2010 Honda VFR 1200
    by Back2-2 » Thu Apr 24, 2014 6:03 pm
    WOW - nice set-up! Somebody got a big tax refund :shock:
    Good job ! 8)
  • EndGame
    by EndGame » Thu Apr 24, 2014 6:06 pm
    crazybrother wrote:So when your new tailight gets destroyed...(Mine did) Check these out:
    You know I was thinking that to myself earlier that this rear tail light was going to only take a few good wackes and be done for. Thanks for the heads up on that other setup!
    2006 CRF450R
  • EndGame
    by EndGame » Thu Apr 24, 2014 6:08 pm
    Back2-2 wrote:WOW - nice set-up! Somebody got a big tax refund :shock:
    Good job ! 8)
    No tax refund... Just a good job and a awesome lawyer wife that let me go all out for my 30th birthday present, and thank you!
    2006 CRF450R
    by Back2-2 » Thu Apr 24, 2014 8:11 pm
    Good job ! 8)
    Sweet ! 8)
Users browsing this forum: JimDirt and 12 guests
