by JimDirt » Fri Apr 11, 2014 10:07 am
If you took the center bolt out nothing should be holding it in , does it look like its been hammered on at the splines ??
the only thing that it could be is the splines or the end of the shaft burred , did you try tapping it IN to see if it moves ?? , i am guessing unless its rusted on , it has to have something where the bolt goes and the spline is that is keeping it from sliding off
