02 450r Annyone have this problem before???
  • Piercelife
    by Piercelife » Sun Apr 06, 2014 9:16 am
    New to the forum wondering if anyone out there has had this problem before. I bought this 02 450r last summer after riding a few weeks (less then 10 hrs) I had cam trouble and bent exhaust valves. I replaced both and started it up still heard some rattling. I found a crack in my cylinder and replaced that. Started it up sounds fine everything's great. Then today I started it up for an actual ride. Rode for a few minutes before it started dying, it will run and after it dies it's easy to start again but it will start acting like it's not getting a gas in short lapses until it completely dies and I roll to a stop. Also if I coast to a stop it will die. Though it will idle fine. Anyone have any idea what this could be? Thanks.
    by JimDirt » Sun Apr 06, 2014 5:14 pm
    Sounds like it could be one of a few issues or a combination of a few issues
    Start with this:
    You did not mention if you cleaned or replaced the jets , or even pulled the carb and/or float bowl to make sure its not "green" inside and that everything is clear
    Have you checked to determine if the float level is correct ?
    Have you eliminated the Kill Switch/button from being bad by unplugging it and riding ?
    Have you eliminated debris in the tank pickup ?
    Have you made sure that the vent on the gas cap is clear ?
    Did you put in FRESH PREMIUM gas ?? (these bike dont like old gas , **longer than 2 months old**), and wont run on Regular worth a crap if they will start at all on Regular , "FRESH" 91 octane or better
    This should give you some things to eliminate ! , hope that helps ...I have never had any issue like that with my 02
  • Piercelife
    by Piercelife » Sun Apr 06, 2014 5:57 pm
    Jimdirt.
    Thanks for the suggestions. Going to pull my carb and clean it somtime in the next few days. Have not checked float level. I have it wired to a key switch and it idles fine. Only when I ride does it die. As far as debris in the tank again it idles fine. Yes i rode it with gas cap off and still had problems. The gas has been sitting for a few months. I'll drain the tank and fill it with fresh. Thanks again.
    by JimDirt » Mon Apr 07, 2014 2:40 pm
    No problem , hopefully it will be one of the things i mentioned , though it could be a intermittent electrical problem , which will be harder to trace out , but usually a CDI or Stator issue , it will not start right back up ,that is why i am looking at possible fuel issues
    keep us posted !
