2006 450R- Oil and tranny oil change
Posted: Mon Jan 05, 2009 6:49 pm
by minibikepilot
I just picked up this bike and want to change the oil and tranny oil..I need some specs on this, how much to put in each side and what weight should I use...2006 450R
Thanks
Posted: Wed Jan 07, 2009 2:27 pm
by minibikepilot
What's up??..No Info..everybody must be busy changing their oil???? :shock:
Posted: Wed Jan 07, 2009 3:35 pm
http://www.ahm-ownerlink.com/assets/OWN ... RF450r.pdf
Here's the owners manual for your bike.
Oil change info starts on page 40.
Posted: Wed Jan 07, 2009 7:20 pm
by minibikepilot
Thanks..I really appreciate it... :D
I'm sure I'll have many questions..Thanks again
Posted: Thu Jan 08, 2009 7:42 am
by nedirtbikr
Follow instructions for engine oil. Have used RotellaT 15W40 on mine since new (also an '06.) Available at Wally World for about $9/gallon. Use in both sides.
When doing tranny, use between 3/4 and Full quart for best performance. Don't trust fluid bolts for correct amount....measure.
Typically change the engine oil between 5 and 10 hours. Change tranny every other oil change. Keep that air filter clean. Buy extras so you're never tempted to ride a dirty one.
Enjoy the bike! You got a great year!
Posted: Thu Jan 08, 2009 8:59 pm
by minibikepilot
Thanks for the tips..I'm really happy with the bike..POWERFUL...
I'm the 2nd owner, I don't think the 1st guy changed out the tranny oil..it makes a little more noise in the motor than i think it should....needs to be adjusted..it doesn't even have 20 hours on it..
Thanks again
Posted: Fri Jan 09, 2009 6:33 am
by nedirtbikr
minibikepilot wrote:Thanks for the tips..I'm really happy with the bike..POWERFUL...
Thanks again
Is it a high pitched noise? If so, it's quite possible that the previous owner followed the manual when servicing (not his fault.) Assuming nothing bad has happened, that noise is likely the tranny squealing about not having enough juice. If it is, that noise will go away with a fresh change and 3/4 - 1 quart oil in the tranny.
Also, to help save costs, it seems to be just fine changing your oil filter every other oil change (I do.) Many do it with no harmful effects.
Re:
Posted: Sun Feb 18, 2018 9:13 am
by Bryan b
rotella 15w40 engine oil for both sides ? Oil and transmission ?
Re: 2006 450R- Oil and tranny oil change
Posted: Sun Feb 18, 2018 9:14 am
by Bryan b
Your saying to put engine oil rotella t 15w40 in engine and transmission ?
Posted: Sun Feb 18, 2018 9:29 am
Just so you know , the last post on this topic was 2009 ...... But to answer your question , you can run the Rotella in Both Sides , i personally used 5w-40 Full Synthetic
