HOW TO: ProMotoBillet End Cap Install
    by Asmith » Fri Jun 29, 2007 10:21 pm
    Project: Modify your CRF 450R exhaust can and convert for trail use by installing the ProMotoBillet Endo end cap with spark arrestor.
    Tools needed: Drill, 3/16” drill bit, Hi Temp Silicone Sealant, Rivet Gun, Center Punch, 1/16" Pin Punch, Hacksaw, Allen wrench
    Step One:
    Use a 1/16" pin punch and a hammer to drive the stainless steel rivet pins through the rivet.
    Step Two:
    Using a 3/16” drill bit, drill out the existing rivets holding the stock end cap in place, make sure to remove the head of the rivet.
    Step Three:
    Use a pin punch or similar device and a hammer, push the rivets through the hole and through the stock end cap.
    Step Four:
    Pull the stock end cap out of the muffler. Remove all
    pieces of the old rivets from the packing material inside of the muffler canister.
    Step Five:
    Cut off the portion of the inner core that is sticking out of the muffler so that it is flush with the outer canister of the muffler. This is easily accomplished with a hacksaw. Be careful not to cut into the aluminum canister. The inner core must be flush with the aluminum canister or the spark arrestor screen could be damaged.
    Step Six:
    Smear a small amount of silicone sealant to the stepped portion of the new end cap receiver and around the receiver of the inner core. I used this sealant ( Hi Temp Silicone ).
    Step Seven:
    Install the new end cap receiver, make sure that the receiver is pushed up tight to the muffler.
    Step Eight:
    Install one rivet at a time by drilling a 3/16” hole at each rivet hole location. Each time you drill a hole and install a rivet make sure that the end cap is pushed up tight to the muffler.
    Install rivet.
    Step Nine:
    Clean up excess silicone sealant with Lacquer Thinner or Carb cleaner and paper towel.
    Step Ten:
    Insert the spark arrestor screen and check for clearance with the inner core.
    Step Eleven:
    Install the cone nozzle with three M6 bolts using an Allen wrench.
    Finished!!!!
    Optional Step Twelve:
    Remove lower M6 Bolt and install Quiet core.
    poway450
    by poway450 » Mon Jul 30, 2007 2:40 pm
    does anyone know if this decreses the power on the 450r
  • raiders_best
    by raiders_best » Sun Aug 12, 2007 7:52 pm
    Does the quite core only fit if You have that tip that points down because when i went to my local shop i asked for the quite core and i just got the core no extra little tip?
    by Asmith » Sun Aug 12, 2007 8:00 pm
    The tip that points down IS the quiet insert...what did you buy???
  • raiders_best
    by raiders_best » Sun Aug 12, 2007 8:06 pm
    i will post a pic soon I bought what ever quite core they gave me with the end cap.
  • WOJIN
    by WOJIN » Tue Aug 14, 2007 9:23 am
    my end cap did not come off easy at all. i went through hell with it for about 2 hours. ripping out the silicon, heating it up, beating it with a hammer, it just didnt want to come out
    2007 450R
  • nedirtbikr
    by nedirtbikr » Tue Aug 14, 2007 9:35 am
    poway450 wrote:does anyone know if this decreses the power on the 450r
    Wondering this also...
    BTW, Agent...nice write up! Thanks!
    2006 CRF450R (For Sale)
    Jethro
    by Jethro » Tue Aug 14, 2007 10:17 am
    i did notice a little power loss with mine, though it is an older model, but it was very small loss. you can just tell a very very slight sog when you leave on the bottom of a gear that is slightly taller then your speed. other then that no complaints and no tickets from the rangers at state areas.
  • raiders_best
    by raiders_best » Tue Aug 14, 2007 10:23 am
    ^^^^I know what you mean WOJIN lol except I got tired of tring to get off in tacked so it only took about 2 5 mins.
  • WOJIN
    by WOJIN » Mon Aug 20, 2007 8:44 am
    yup thats what mine looked like. i tried to do it all nice and clean, but after 2 hours of that and the realization that its not going back on, i resorted to brute force.
    looks like you tried drilling holes in the tip to pry from too, i tried that as well
    2007 450R
