ALOT OF OIL IN THE CRANKCASE TUBE
  • NorCalDuner
    by NorCalDuner » Wed May 30, 2007 9:25 pm
    I have always got a little oil in the tube ,like 1". Now after a top end rebuild I am getting like 3-4". What might be the problem?
    2005 crf450r Yoshi Slip On
    2006 trx450r ESR full exhaust,
    HCSII cam
    by Asmith » Wed May 30, 2007 9:28 pm
    Is it running OK?? Making good power??
    If the rings didn't seat well, you would have more blowby in the crankcase, thus more pressure forcing out more oil. Just a thought.
    by 124 » Thu May 31, 2007 5:38 am
    Compression in spec?
  • NorCalDuner
    by NorCalDuner » Fri Jun 01, 2007 8:37 am
    The bike is running perfect, with alot of power. That is what is weird. There is no smoke coming out of the exhaust either. Could a breather tube be pinched or something and cause this?
    HCSII cam
    by 124 » Fri Jun 01, 2007 9:30 am
    Are your oil resevoirs staying at their correct levels respectively? If you have a leaky right side crank seal, it will create crankcase pressure.
  • NorCalDuner
    by NorCalDuner » Wed Jun 06, 2007 8:50 pm
    Well, I just took my air filter off to clean it and I have quite a bit of oil in my air box as well. I am really starting to worry. My buddy said it might be because I am running regular oil in stead of synthetic. I put it in to break the new top end in, but I am going to change back to synthetic know. Can the regular oil be foaming? It is honda GN4.
    HCSII cam
    by 124 » Thu Jun 07, 2007 5:29 am
    Seriously doubt it has to do with the oil type, but anything is possible. As I asked before, are your fluid levels staying correct?
  • CAMERON
    by CAMERON » Mon Jun 11, 2007 2:18 pm
    You need to plug up the hose from the air box and run the hose from the valve cover down by the rear shock by the carbs. vent hoses.
    KevinM
    by KevinM » Wed Jun 13, 2007 11:39 am
    CAMERON wrote:You need to plug up the hose from the air box and run the hose from the valve cover down by the rear shock by the carbs. vent hoses.
    Well, there's a kit from Applied Racing and Tokyo Mods for that.. but you need to find out what's causing the oil to blow into that vent.
    Could this be caused by too much oil on the engine side?
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • NorCalDuner
    by NorCalDuner » Thu Jun 14, 2007 10:03 pm
    Last weekend I changed all the fluids and put synthetic in the top. We did a 70 mile trail ride and there was only a few drops that came out. So I think what happened last time was the high reving at the sand dunes. But I will still keep an eye on it.
    HCSII cam
  • Dalmo
    by Dalmo » Sat Aug 11, 2007 10:48 pm
    :?: Hi I had this same problem with my old 05CRF250X took it in for the top end to be done and every ride after that oil in breather and all over air filter man I was getting annoyed with the mess it left me to clean up so I took it back to dealer and it had them stumped in the end all I did was not fill crankcase right to its full level and this problem went away, anyway I fixed it also buy stepping up to the mighty 450r!!!
    06CRF450r
    Tag Bars
    Full Bills Thunder Exhaust System
  • fatbasser
    by fatbasser » Sun Aug 12, 2007 10:26 pm
    when i used to own my 450 everytime i would go riding and hold wheelies for a long period of time i would get a lot of oil build up in the air box which was coming out of the breather hose just a thought
