07 Water Pump Seal ??
  • k7033h
    by k7033h » Thu Apr 19, 2007 12:45 pm
    I noticed at the Honda shop today that the 07' has a different water pump seal. It uses the same shaft and same oil seal. I bought the 07' seal for my 05'. It has some white plastic on the inside that the shaft spins in. Everything else looks the same. I am going to try it out tomarrow to see if it works. I am getting tired of changing out my water pump shaft, bearings and seals. 4 times in 2.5 years thats just way to many. Has any one else tried the 07' seal for the 02-06 crf450's ?
    braap207
    by braap207 » Thu Apr 19, 2007 1:43 pm
    :? I feel your pain my friend, I almost had to sit out the season championship race due to those damn seals, but I learned fast to keep 2 sets in the tool box. The seal you are talking about (07) is different than the 02-05 when I just changed mine this weekend a honda mechanic said he had an extra set, which included the seal with the white collar, thats not need on the 02-05. If you look on www.planethondaracing.com they have the parts fiche and its easy to read. You only need 2 seals and 1 bearing for your bike. The part number are-91001-KA4-003, 91201-148-003, 91201-965-000. The part numbers may be different from each year but I've used 02's in 04's and they match. :twisted: :twisted: :twisted: :twisted:
    I don't ride dirty I ride canadian...
    05/06 NDMA MX Am State Champ
    Your Mom goes to college is currently serving in Iraq
  • k7033h
    by k7033h » Fri Apr 20, 2007 1:53 pm
    Well its not plastic. I need my water pump today and the 07' seal just has a lubricant on it. Thats it. We will see if it works any better.
    braap207
    by braap207 » Sat Apr 21, 2007 6:44 am
    Not sure I'm understanding the 07 just has lubricant? They should come with grease in the inner ring of one of the seals. The new part I'm talking about is rubber and white plastic combined, no 07 parts fiche out yet so I'm not sure. But yes the inner ring is plastic. White and Balck piece. :twisted: :twisted: :twisted: :twisted:
