Clinking noise on 05 450r during take off and accelerating
Posted: Sun Apr 01, 2007 1:31 pm
by kiwiflyer
Can anyone suggest a cause for the following problem? When I take off on my 05 450r I get a clinking noise from somewhere down below. This only happens periodically and normally when the power is wound on in 1st and 2nd. I think it may be the chain slipper slapping against the swing arm but cant seem to isolate the problem. I have checked chain tension etc. Has anyone else encountered this?
Posted: Sun Apr 01, 2007 4:17 pm
by T.RexRacing
Yeah it's the chain whacking the swingarm.Annoying but no problem.I try to run higher rpms but you can't always do that.You get used to it.
Posted: Wed Apr 04, 2007 12:33 am
by kiwiflyer
Cheers,
The chain isn't actually hitting the swingarm, but thought it could be the slap of the small gap between the slider and the swingarm. I have heard of putting silicone glue between the slider and the swingarm. This should also reduce any swingarm wear. Anyone have any other ideas?
Posted: Wed Apr 04, 2007 5:27 am
by 124
There are aftermarket companies that provide new chain sliders that are supposed to eliminate this phenemonon. Can't think of any names right now...sorry.
Posted: Wed Apr 04, 2007 8:36 am
by MadMatt
Mine does the same thing, I just adjust the chain and it seems to fix it so far.
this might help
http://rubicon.off-road.com/dirtbike/pr ... /tmdesign/
Posted: Wed Apr 04, 2007 4:45 pm
by T.RexRacing
kiwiflyer wrote:Cheers,
I did the silicone thing.Worked for awhile and had to reapply.Oh and I meant the slider not the swingarm.
