Just for comparison, I run the following:Mr Smith wrote:I just caught on to you saying its got a 165. The R comes stock with a 170 main. Did you get a manual with it? In the back shows the stock jetting the R comes with and the correct needle settings. I would take the carb to those specs exactly and tear out the backfire screen in the air filter if its still got one. Put the fuel screw at 1 1/4 and you should be good to go if theres no mechanical problems. I also run Engine ice in my R...Helps the overheating issues 150%
Well, you definately need a new pump seal there. Fluid from the weep hole shouldn't really have anything to do with your "choke on/off" related running problems. Make sure your rads aren't REALLY low on coolant.dirtrider67 wrote:i just realized that the coolant is comming from the water pump weep hole. could this have anything to do with the way it's running?
Users browsing this forum: Google [Bot] and 6 guests
