05 450F Engine Seized.........Looking for some help.
Posted: Fri Nov 24, 2006 8:53 pm
by dwhite77
Orange County, CA. Seized the engine, actually the piston busted through the cylinder walls and left two holes....... Not looking to get raped by the bike shop. Any suggestions on who to go to or ideas where I can could find an engine or crate motor????? So bummed right now! :cry: :(
Posted: Fri Nov 24, 2006 9:21 pm
450 R or 450 X ?
Posted: Fri Nov 24, 2006 9:25 pm
by dwhite77
my bad......450R
Posted: Fri Nov 24, 2006 9:55 pm
Well, two ways to go on this one.
Rebuild or Crate Motor.
The Crate motors are available, new about $3000
Rebuild: new 490cc piston and cylinder/gaskets: $695
http://www.crfsonly.com/catalog/product ... e9044ec534
new crankshaft and connecting rod: $281
http://www.crfsonly.com/catalog/product ... 2343b63b1c
So for roughly half the price of new you can rebuild a beast of a motor and have the best of everything.
Good Luck!
Posted: Sat Nov 25, 2006 9:42 am
by dwhite77
the cylinder walls are shot! the Piston busted through the wall and left two gaping holes. I definitely need a new cylinder as well. Somehow i lost all the fluid in the radiator causing the bike to obviously way over heat!!!! So bummed, I want to be riding right now!
Posted: Sat Nov 25, 2006 9:54 am
dwhite77 wrote:the cylinder walls are shot! the Piston busted through the wall and left two gaping holes. I definitely need a new cylinder as well. Somehow i lost all the fluid in the radiator causing the bike to obviously way over heat!!!! So bummed, I want to be riding right now!
The $ 695 price includes the cylinder and piston and gasket set.
Posted: Tue Dec 05, 2006 2:06 pm
by braap207
Is there any other damage to the lower end? If not your in good shape, you can get a used piston and clinder off Ebay for next to nothing. I would take the engine out and clean it well to make sure there is no debris left in the tranny or head. If you only damaged the cylinder and piston your just damn lucky! If you buy an entire engine I'll buy the tranny from you! :twisted: :twisted: :twisted:
Posted: Thu Dec 14, 2006 8:57 pm
by dwhite77
well i ordered all new parts, valves, cylinder, piston, crank, gaskets, pins, clips, etc......should be up and runnign by tomorrow! Thanks for the help guys!
Posted: Thu Dec 14, 2006 9:18 pm
by Mr Smith
dwhite77 wrote:should be up and runnign by tomorrow! Thanks for the help guys!
Wow...Whos doing the work since the cases are gonna have to be split? Thats allot of work to do in one day unless you know a guy who knows a guy...
