05 450F Engine Seized.........Looking for some help.
  • dwhite77
    by dwhite77 » Fri Nov 24, 2006 8:53 pm
    Orange County, CA. Seized the engine, actually the piston busted through the cylinder walls and left two holes....... Not looking to get raped by the bike shop. Any suggestions on who to go to or ideas where I can could find an engine or crate motor????? So bummed right now! :cry: :(
    by Asmith » Fri Nov 24, 2006 9:21 pm
    450 R or 450 X ?
  • dwhite77
    by dwhite77 » Fri Nov 24, 2006 9:25 pm
    my bad......450R
    by Asmith » Fri Nov 24, 2006 9:55 pm
    Well, two ways to go on this one.
    Rebuild or Crate Motor.
    The Crate motors are available, new about $3000
    Rebuild: new 490cc piston and cylinder/gaskets: $695
    http://www.crfsonly.com/catalog/product ... e9044ec534
    new crankshaft and connecting rod: $281
    http://www.crfsonly.com/catalog/product ... 2343b63b1c
    So for roughly half the price of new you can rebuild a beast of a motor and have the best of everything.
    Good Luck!
  • dwhite77
    by dwhite77 » Sat Nov 25, 2006 9:42 am
    the cylinder walls are shot! the Piston busted through the wall and left two gaping holes. I definitely need a new cylinder as well. Somehow i lost all the fluid in the radiator causing the bike to obviously way over heat!!!! So bummed, I want to be riding right now!
    by Asmith » Sat Nov 25, 2006 9:54 am
    dwhite77 wrote:the cylinder walls are shot! the Piston busted through the wall and left two gaping holes. I definitely need a new cylinder as well. Somehow i lost all the fluid in the radiator causing the bike to obviously way over heat!!!! So bummed, I want to be riding right now!
    The $ 695 price includes the cylinder and piston and gasket set.
    braap207
    by braap207 » Tue Dec 05, 2006 2:06 pm
    Is there any other damage to the lower end? If not your in good shape, you can get a used piston and clinder off Ebay for next to nothing. I would take the engine out and clean it well to make sure there is no debris left in the tranny or head. If you only damaged the cylinder and piston your just damn lucky! If you buy an entire engine I'll buy the tranny from you! :twisted: :twisted: :twisted:
    I don't ride dirty I ride canadian...
    05/06 NDMA MX Am State Champ
    Your Mom goes to college is currently serving in Iraq
  • dwhite77
    by dwhite77 » Thu Dec 14, 2006 8:57 pm
    well i ordered all new parts, valves, cylinder, piston, crank, gaskets, pins, clips, etc......should be up and runnign by tomorrow! Thanks for the help guys!
  • Mr Smith
    by Mr Smith » Thu Dec 14, 2006 9:18 pm
    dwhite77 wrote:should be up and runnign by tomorrow! Thanks for the help guys!
    Wow...Whos doing the work since the cases are gonna have to be split? Thats allot of work to do in one day unless you know a guy who knows a guy...
