Welcome to the site !!I have 2020 crf450rwe and have same problem so I end it up to add momentary switch to by pass a 12 volt to low current starter relay and I just call it problem solved
What was the cause of your starting issues ??? , was it working fine , then the next time it would not start ?? , I have not had any issues with my 2020 and I am just hitting 100 hours on it with not 1 issue with anything electrical or mechanical (aside from wear parts like chain guides , chains and tires and brake pads), so I am trying to find a common symptom or cause between all these posts that is causing these issues , and they all seem to be caused by a different issue , is what I am seeing , but giving the same results/problem
